Cisco877 dropout issues
Jul 13th, 2008
Hi There,
I have a Cisco 877 router on a remote site, connected to an ADSL service servicing 5 users. It has been working fine except till lately; it started to drop out, currently it drops out an average of 3-4 times a day. Our provider has done different tests in the line and have found no issues with it. What i found strange is the "Total output drops" value from the "show int atm0" command, which is shown below, after one hour it was last rebooted. It seems that the external buffers are not coping with the traffic going thru...
ATM0 is up, line protocol is up
Hardware is MPC ATMSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 832 Kbit, DLY 440 usec,
reliability 255/255, txload 52/255, rxload 97/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
10 maximum active VCs, 1024 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2547
Queueing strategy: Per VC Queueing
5 minute input rate 317000 bits/sec, 44 packets/sec
5 minute output rate 170000 bits/sec, 39 packets/sec
523222 packets input, 327234720 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
580974 packets output, 277304847 bytes, 0 underruns
Can someone please assist with what will be the right way to minimise the traffic going thru this interface? This router is connected to the main site LAN by an site-to-site tunnel (ipsec) so i still need to allow netbios and microsoft-ds traffic across this link.
Steve
