VPN not comming up
Jul 13th, 2008
my vpn not comming up i have checked the plicies which is ok. my one end is cisco 611 and other is Netscreen.
i am getting the following error:
%CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 203.x.x.244
This indicate that there is a phase 2 mismatch .but i have checehed the pame at both end.
my configuration which is same at both end.
My vpn is not comming up
Plz suggest me a solution
My config is as follows:
crypto isakmp policy 25
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key TataMotorsIndia address 203.x.x.244
crypto ipsec transform-set mymap ah-md5-hmac esp-3des
crypto map tunnelmap 10 ipsec-isakmp
set peer
set transform-set mymap
match address 101
interface FastEthernet0/1
ip address 123.x.x.98
ip virtual-reassembly
duplex auto
speed auto
access-list 101 permit ip host
Daniel Voicu Sun, 07/13/2008 - 23:52
The problem is with the transform set.
no crypto ipsec transform-set mymap ah-md5-hmac esp-3des
crypto ipsec transform-set mymap esp-3des esp-md5-hmac
This will use only ESP for VPN, and the Phase 2 parameters are: 3DES, MD5
Please rate if this helped.
