CAR Load. What is it?
Jul 13th, 2008
Should CDR Load be enable? In the 23:00 CPU uses 80 percent of loading and I identified that this problem get into touch with CAR (CDR load).
I think it's not normal situation.
Can anybody help me?
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 07/14/2008 - 03:33
CDR insert (as the name says) is the service that inserts flat files into CDR DB
CAR loadres is the service that takes the CDR info and loads it into ART
load for CDR is handled by enterprise parameter: CDR File Time Interval
for CAR it's configured under the CAR tool itself
if this helps, please rate Mon, 07/14/2008 - 05:10
Can I stop CDR load for this page?
Forexample,I can say that CDR is used for saving all information of calls.
And what is the purpose of the ART?
Jaime Valencia Mon, 07/14/2008 - 05:16
CDR is raw data from calls (usually used for 3rd party billing), ART is for CAR usage
Jaime Valencia Mon, 07/14/2008 - 10:41
you can disable CDR load if you do not use the info from CDR DB
you can disable CAR loader if you do not use info from ART DB
if this helps, please rate Fri, 07/18/2008 - 06:40
I want to save CDR as it works now. But I have a doubt, what is the defference between disable all CAR service and onlu CDR load?
Jaime Valencia Fri, 07/18/2008 - 09:05
i already answered this on the 2nd response
CDR can work without CAR services
CAR CANNOT work without CDR services
CDR is raw data that is then migrated to CAR if configured. independent DBs
