Intermittant problem Wireless lan controller AIR-WLC2106-K9
Jul 13th, 2008
There is an intermittant issue with this WLC. Customer has rebooted twice. Now its been working fine.
WLC was giving the following error before it went down.
Crash Dump
Software was stopped by the reaper for the following reason:
Reaper Reset: Task “pemReceiveTask” missed software watchdog
Error Log
Thu Jul 10 02:59:58 2008 [ERROR] iapp_socket_task.c 399: iappSocketTask: iappRecvPkt returned error
Thu Jul 10 02:59:58 2008 Previous message occurred 8 times
Device info:
Model No: AIR-WLC2106-K9
Serial No: JMX1113K0VK
Software Version: 4.0.206.0
Please help me out in finding the root cause of this issue; I would appreciate your prompt response on this issue.
-Ismail Mohammed
Scott Fella Mon, 07/14/2008 - 03:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If this keeps hapeing, then most likley it is a bug.... I have seen this on the release notes on some of the code, but don't know if it affects this one.... looks like it does. I would upgrade to 4.1.185, which is a Cisco safeharbor code. I run that code on most of my installs unless they have 1252 ap's, then I will run the 4.2.130. You can also open a TAC case if you like.... they migh just tell you the bug idea and then to upgrade the controller code.
Trending Topics - Security & Network
