IPSec tunnel
Jul 13th, 2008
I have main office " A " where I have a PIX 525 with 3DES and DES enabled,and then I have two other branches " B " and " C ".at "B" I have a PIX 525 with 3DES and DES enabled,and at "C" I have PIX 525 with only DES enabled.
Now I am trying to create IPSec tunnel between "A" to "B" with 3DES and IPSec between "A" to "C" with DES
Is it possibe?Means from a PIX525 (3DESand DES enabled) is it possibe to create a IPSec tunnel between two other site with one site 3DES and with another site DES.
Please send me the link.
Thanks and Regards,
S.Venkataraman.
Overall Rating: 4 (1 ratings)
Lavanholy Mon, 07/14/2008 - 01:26
Hi Aleskseev,
Yea,you are correct,One IPSec tunnel is 3DES to 3DES the other one is 3DES to DES.Is this possible?
Thanks and Regards,
S.Venkataraman.
a.alekseev Mon, 07/14/2008 - 01:35
Yes, you can create IPSec tunnel between "A" to "B" with 3DES encryption and IPSec between "A" to "C" with DES encryption.
But better way is to obtain a 3DES license.
Lavanholy Mon, 07/14/2008 - 01:44
Hi A.Alekseev,
Fine .Thanks a lot.How to activate this 3DES key?Please send me any link or guide me how to activate the 3DES key?
Best Regards,
S.Venkataraman
