rogger as IPCC domain controller
Answered Question
Jul 14th, 2008
We have rogger1(Side A) and Rogger2(side B) redundancy at our site. Both run in syncronized mode. Rogger1 is domain controller and all the ICM servers are members of its domain. In case of failure of Rogger1, call routing is handeled by Rogger2 and no effect on IPCC. My query is that during the downtime of Rogger1 (i.e. Domain controller), if we need to restart any of the ICM servers, using which login account (domain or local) we can logon to that server? can we still use the domain login? Will using the local login account start the ICM services on that server without affecting IPCC operations?
Overall Rating: 4 (2 ratings)
lpezj Mon, 07/14/2008 - 00:36
  • Gold, 750 points or more
If you are running ICM version 7, Roggers can not be domain controllers. If you are running previous version the Roggers must be domain controllers.
RoggerA in previous versions is the main Domain Controller and Rogger B must be the back up domain controller.
If the domain controller is not available, you can not start up any component related to SQL Sever (Logger, Distributor, HDS, Dialer). In this case Windows security is used mainly for SQL Server autenthication. You will need to restablish the Domain Controller to have your system up and running.
Hope this helps,
Juan Luis
K_require Mon, 07/14/2008 - 02:14
we are using ICM 6.0 in our setup. Can I find out the server role by issuing any command? After issuing nslookup & dc command, my server ip is coeerectly displayed but server name is displayed as unknown.
Riccardo Bua Mon, 07/14/2008 - 05:48
  • Cisco Employee,
try using LMHOST and preload you domain and DC info on the hosts, this should help.
You will need a DC available to satisfy the login requests.
Riccardo
