Warning message
allow msn messenger through cisco router
Jul 14th, 2008
My configuration:
internet - linux router - (acl 104, in)cisco router(acl 102 in)
-acl 102 is for originating traffic for 172.31.0.0/24 and acl 104 is for returning traffic.
router has:
- 172.31.5.0/24 (linux - internet)
- 172.31.2.0/24 (cisco - linux - internet)
- 172.31.0.0/24 (cisco - linux - internet)
I know that msn works with 1863 tcp port, but to be sure I permitet all IP traffic.
For 172.31.0.0.24, I have a VPN IPSEC, esp with nat overload built. acl 106 is (access-list 106 permit ip 172.31.0.0 0.0.0.255 VPN-peer)
For 172.31.0.0/24, I have also acl 102 (access-list 102 permit ip any any) and for returning traffic acl 104 (access-list 104 permit ip any any)
The linux router is just forwording everything that comes from cisco, both directions.
tcpdump -i eth0 | grep 1863:
11:45:51.363235 IP 80.86.103.114.1319 > 65.54.239.140.1863: S 1454326243:1454326243(0) win 65535 <mss 1460,nop,nop,sackOK>
11:45:51.549590 IP 65.54.239.140.1863 > 80.86.103.114.1319: S 1352546280:1352546280(0) ack 1454326244 win 16384 <mss 1460,nop,nop,sackOK>
11:45:51.550343 IP 80.86.103.114.1319 > 65.54.239.140.1863: . ack 1 win 65535
11:45:51.551922 IP 80.86.103.114.1319 > 65.54.239.140.1863: P 1:28(27) ack 1 win 65535
11:45:51.737816 IP 65.54.239.140.1863 > 80.86.103.114.1319: P 1:28(27) ack 28 win 65508
11:45:51.739330 IP 80.86.103.114.1319 > 65.54.239.140.1863: R 1454326271:1454326271(0) win 65508
The VPN is working fine. Only this msn traffic is not working. The subnet 172.31.5.0 which is going drirectly through linux server(not through cisco router) is working fine with msn.
Msn is not working only for the 172.31.0.0 which is going through cisco, then through linux.
I hope u understand the topology.
What is the R (reset) from the last line fron tcpdump output means?
I don't know where to look anymore?
thanks
Spinu Viorel Mon, 07/14/2008 - 02:52
I did a search on Internet and I found this information:
Cisco IOS Firewall Instant Messenger Support Restriction
Cisco IOS firewall supports only the following versions of each Instant Messenger (IM) application:
"Yahoo Messenger supported versions: 6.0.0.1922, 6.0.0.1750, 6.0.0.1671, and 6.0.0.1643
"MSN supported versions: 6.2.0205 and 7.0.0816
"AOL supported version: 5.9.3702
Note All other IM version connections will be reset.
I have MSN 7.0.0.820... I tried to install 7.0.0816 but it says that a newer version is available and if I want to continue I have to install it (the newer version). So I guess this means I can't use MSN with cisco router(I forgot: I have cisco 1812, IOS Version 12.3(8r)YH8)
Can anybody confirm this information?
I thought my problem comes from acl,vpn configuration, but it seems is a aplication version problem!
cisco24x7 Mon, 07/14/2008 - 03:13
  • Silver, 250 points or more
LAN---C2621----Internet
LAN network is 192.168.1.0/24
Internet is 1.2.3.4
C2621 has an IP of 192.168.1.1 on the LAN side
and 1.2.3.4 on the Internet
interface F0/1
ip nat inside
interface F0/0
ip address 1.1.1.1 255.255.255.252
ip nat outside
access-list 100 permit ip 192.168.1.0/24 any
ip nat inside source list 100 interface F0/0 overload
I have a host on a LAN side with Microsoft
MSN version 8.1 and it is working fine.
Furthermore, I am using IOS version 12.3(12)19
with CBAC.
cisco24x7 Tue, 07/15/2008 - 03:29
I have this:
ip inspect name CBAC tcp alert on audit-trail on timeout 43200
ip inspect name CBAC udp alert on audit-trail on timeout 43200
ip inspect name CBAC icmp alert on audit-trail on
ip inspect name CBAC http alert on audit-trail on
ip inspect name CBAC smtp alert on audit-trail on
interface f0/0
ip inspect CBAC out
ip access-group black_hole in
ip access-list extended black_hole
deny ip any any log
