VXML problem
Jul 14th, 2008
I have vxml script and two Ip-phones on CCME.. Locally all works - i call to script number 7804, hear music, press the buttons.. events nomatch and noinput also works.. from CCM (5xxx) i can call to CCME (78xx) and back.. transfer also works... when I call to script, the call is set and script is done according debug and "show commands".. but it only thinks a few seconds and then "busy"...
At CCME side:
application
service menu flash:menu.vxml
dial-peer voice 100 voip
service menu out-bound
destination-pattern 7804 //script number
session target ipv4:172.18.1.1
dtmf-relay rtp-nte h245-signal
codec g711ulaw
no vad
dial-peer voice 13 voip
destination-pattern 5... // CCM numbers
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
From CCM side there is route pattern to CCME numbers
P.S. script and scheme are attached
Yagami_Light Wed, 07/16/2008 - 23:44
nobody knows?.. there is idea, that locally ip-phones are seen like pots.. and when i call from outside - like voip.. and ivr don't want to work with it :(.. our provider also is working to solve this problem
Tim Smith Thu, 07/17/2008 - 00:46
  • Silver, 250 points or more
Start with the basics...
Where is your inbound dial peer?
Have you done a "debug isdn q931" to watch the inbound call from the PSTN and see why it gets disconnected?
First level is to get the call from outside, and get it to match the dial peer with the script on it... you need to verify this is happening.
Cheers,
Tim
Tim Smith Thu, 07/17/2008 - 00:50
You are using G711 on the CME box..
Are your CallManager extensions trying to use G711 also?
Cheers,
Tim
