How to setup that kind of VPN IPSEC?
Jul 14th, 2008
I have a 1841 router with Ifirewall IOS behind a public IP.
On the remote side I have a 1801 which is behind a modem/router.... therefore it has a private adress on its outside interface.
Central Router (Pub IP)---- Internet ---- (Pub IP)Modem/router ---- (Private IP)Router
Is it possible to setup an IPSEC VPN ? I try a lot of thing but nothing work....
Does anyone has a solution with a working configuration?
Rgards
Overall Rating: 4 (1 ratings)
a.alekseev Mon, 07/14/2008 - 01:38
  • Gold, 750 points or more
you need to have a static NAT translation on the Central Router for Private IP of your 1841 router
rdubo Mon, 07/14/2008 - 10:16
I'm not sure I understand your answer....
But something else... The 1801 router is behind a router/modem that get a dynamic IP...
