service-policy output voice-only
Jul 14th, 2008
Hi, when i enter "service-policy output voice-only" in int BVI1 on a Cisco 878 (G.SHDSL), it throws an error saying, "Class Based Weighted Fair Queueing not supported"
Can i put this line in int ATM0 ?
Paolo Bevilacqua Mon, 07/14/2008 - 01:50
  • Hall of Fame,
    Founding Member
It should be done as follows:
Remove BVI and "bridge irb". Configure an ATM subinterface point-to-point with the IP address, "atm route-bridging" and PVC. Under PVC apply the service policy.
please rate post if it helps!
jiaxiongxiao Mon, 07/14/2008 - 03:44
Hi Bevilacqua,
Thanks so much for replying so quickly.
Can i post the configs here ?
Paolo Bevilacqua Mon, 07/14/2008 - 03:58
  • Hall of Fame,
    Founding Member
I understand the config that you have now.
Make the suggested changes and if doesn't work, then post modified config.
