Reconfiguring WLC's Management Interface Gateway
Jul 14th, 2008
Dears
I am trying to change gateway which was previously configured wrong.But facing error.Below is command which i am using and error facing.
configure interface address managent IP-ADDRESS SUBNETMASK GATEWAY
"Request failed - Active WLAN using interface. Disable WLAN first
Overall Rating: 4.3 (3 ratings)
Scott Fella Mon, 07/14/2008 - 03:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You have an ssid (wlan) mapped to the management interface. Disable that ssid and then you will be able to change the mangement interface configurations.
Richard Atkin Mon, 07/14/2008 - 05:19
  • Silver, 250 points or more
WLANs can be disabled in two ways; CLI or GUI.
CLI
config wlan disable
or GUI
WLAN tab
Click a Profile Name
Uncheck the "Enable" checkbox
Apply
