ip sla cuom 2.0.3
Jul 14th, 2008
what is this for?, i know that is for a kind of test -> (phone status test) but how i configure this?, in all routers and swithes ?, the command is "ip sla responder" ?,
Need some help with the ip sla.
htarra Fri, 07/18/2008 - 06:24
If you get to the 12.4X line of code above IP base you should be fine otherwise it will not support. The commands will all start with "rtr" and not "ip sla". The ip sla commands were not added until 12.4.
