Call Forward member of hunt group
Jul 14th, 2008
My client uses an UC520. All phones are member of a hunt group.
They want to use call forward on their phone, but settings are being ignored. (I assume because they are member of the hunt group).
What options do I have to allow the client to forward calls to an external number without me changing system settings?
Kind regards,
Paolo Bevilacqua Mon, 07/14/2008 - 02:41
Yes, CF is ignored by desing for DNs that are part of hunt-group.
If the need is to have someone else temporary take calls for the hunt-group, you can use Hlog button, or dynamic join to hunt-group.
Else if you want to have another DN that behave normally no matter the hunt-group, you need to configure anothe DN and assign it to another button.
Please rate post if it helps!
Ayodeji oladipo... Mon, 07/14/2008 - 02:42
The only setting you can use is on the hunt pilot itself.
You can set a CFNA on the hunt pilot, such that if no memeber answers the call will go to the external number..
or you can manually configure a CFW all on the hunt pilot.
Your other option is to configure time of day routing, if the users have a specific time they want calls not to go to the hunt group members
