using routing protocols with isdn
Jul 14th, 2008
Hi all, I have seen my isp's router today, there config seems to have no static routes with a higher admin distance than BGP as I would suspect, to stop the updates bringing up the line. how would they achieve this? as the line only comes up when the primary fails.
Giuseppe Larosa Tue, 07/15/2008 - 12:50
Hello Carl,
they are using some form of DDR Dial on Demand Routing or simply the backup command to declare that the isdn is the backup of main interface.
Then, with isdn you can define in a dialer-list what traffic is interesting (= will reset the idle timeout). Usually the idea is to use an extended ip acl where you deny the routing protocol so that BGP keepalives will not keep the ISDN line up all the time.
Look at the following link
Hope to help
