personalize menu unity 4.2(1)
Jul 14th, 2008
Hi to all,
i would like to personalize a menu in unity 4.2.1 so when someone calls give a menu to leave a message o redirect the call to a group of numbers.
How can i do this?
best regards
Jaime Valencia Mon, 07/14/2008 - 03:40
  • Cisco Employee,
  • Hall of Fame,
    2011
not sure whether you want to create a new keymap, if so use Custom Key Mapping tool
or if you're just trying to create a very basic greeting with options. or a call handler.
if the 2nd just record the greeting and use the caller input options
javalenc
if this helps, please rate
