lee.reade Mon, 07/14/2008 - 04:13
  • Silver, 250 points or more
CAT0S is layer 2 only, therefore you wont have an interface vlan 888 as this will be Layer 3, you must session onto the msfc and then issue the normal ios command, show interface vlan 888.
Here you will find all the info you are looking for.
LR
loytakmem Mon, 07/14/2008 - 04:14
Oh,
Ok, I give it try. Thanks for the swift reply.
