want to connect my 4 remote offices by tech. how?
Jul 14th, 2008
want to connect my 4 remote offices by tech. to share data and voice.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Mon, 07/14/2008 - 05:23
If you're the end user, you should locate a reliable cisco partner.
He/she will configure VPN over the internet using cisco routers.
rajozkee2008 Mon, 07/14/2008 - 06:00
basically one of my friend suggested to use CISCO Router 1841 n Sitch 2960 n 3500 with IP Phones with a connectivity using Wireless Access Point, UTM box and IPPBX....to me confusing? how does it actually work??
I stay in Kolkata, India,I need to know local Cisco Partner whereabouts as well
Paolo Bevilacqua Mon, 07/14/2008 - 08:42
Hi, the details of the routers to use can be very different and can be defined only after an analysis.
You can get the official list of cisco partners on this website, under "partner central".
Please rate post if it helps!
