2950 switch and vlan access
Jul 14th, 2008
Okay, so I'm wondering if this is possible...
I have one port that I want to plug machines in. They can either be on vlan 1 or vlan 189. Is there any way to set up the "switchport access vlan #" command to make it so that both those vlans have access to it?
Collin Clark Mon, 07/14/2008 - 05:34
  • Purple, 4500 points or more
Not as an access port.
Hope that helps.
bvsnarayana03 Mon, 07/14/2008 - 05:38
  • Silver, 250 points or more
There are specific cases when you use 2 different vlans, 1 for voice & other for data. This is what you do when your port participates in both voice & data.You specifically mention which vlan is for voice & which is data. Done as follows:
int fa0/0
switchport mode access
switchport access vlan 100
switch voice vlan 200
Other than such case, you cant have a single port as part of 2 vlans simultaneously.
