traffic policy on ASA
S M85
Level 4
Level 4
I was wondering if it was possible to make a traffic policy where i can decide to push trafic to another inside interface.
For example we are using 2 ports on the ASA 1 outside, second one for inside. On the inside there are several customers on the same trunk interface.
One customer of ours want to inspect his trafic for spam and several other kind of purposes (baracuda webfilter). Is it possible that i can make a traffic policy to filter my customers traffic. And forward that to the 2 other interfaces on ASA. SO that only the traffic of that customer flows trough INSIDE -> APPLIANCE -> OUTSIDE.
The other solution would be to remove the customer from the trunk and placed that on the 3rd interface of the ASA but then i need another port on the shared switch. (so than it would be INSIDE CUSTOMER -> LAN BARACUDA -> WAN BARACUDA -> INSIDE ASA "customer B" -> OUTSIDE ASA)
I really appreciate if someone knows an answer to my first question.
regards,
Sander
Marwan ALshawi
sure it possible
what you need to do it make sube interfaces on your inside interface
then you need to make you ASA in mutiple context
and assigne each customer to a defrent context and alocate each inside interface to defrent context and assign the outide interface to all context
so in this way ur ouside interface will be a shared interface between them all
in this way you can handel each context as saparat virtual firewall and apply deffrent policy and ACLs.. so on
but without VPN
good luck
Rate if helpful
