Masking Number in Unity.
Jul 14th, 2008
Hi everyone.
If a customer gets through to voicemail and presses 0 to get to reception. The number that is masked comes up as the Voicemail Port Number (e.g 8101 or 8102, or 8103 etc...) I would like the number of the person that is calling to be displays on the phones in reception.
For example, I ring 4093349 from 12345678 and reach the persons voicemail. Unity informs me that I can dial 0 for reception. When I dial 0, the number that is displayed on the CLID on the phone is 810x(where x can be any number).
The 810x are voicemail port configured in Call Manager and are a member of a Hunt Group. I would like the callers number 12345678 to display on the CLID of the receptions phone.
Can anyone shine any light on this?
Overall Rating: 5 (3 ratings)
Jaime Valencia Mon, 07/14/2008 - 06:43
  • Cisco Employee,
  • Hall of Fame,
    2011
Bug Details
Calls from Unity AA display VM port number on phone display prompt line
they added this parameter:
Display Original Calling Number on Transfer from Cisco Unity
this is only for CUCM 4.2(3) and 6.x versions. since CUCM 5.X is based in 4.1(x) you cannot find it on those versions.
javalenc
if this helps, please rate
Anthony O'Reilly Mon, 07/14/2008 - 06:52
Hi Javalenc,
Many thnaks for the super quick response.
I am far from being a guru in Unity. Where do I set this paramenter? Is it in Unity advanced Tools?
Jaime Valencia Mon, 07/14/2008 - 06:55
  • Cisco Employee,
  • Hall of Fame,
    2011
in CUCM
javalenc
Rob Huffman Mon, 07/14/2008 - 07:07
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Anthony,
Just to add a touch to the great tips from Jaime (+5 points for this Jaime :)
Here is where to change this setting;
ccmadmin> Services> Callmanager Service> Clusterwide Parameters (Device - Phone)> Display Original Calling Number on Transfer from Cisco Unity> **change to True
Hope this helps!
Rob
