VPN Client and Westell 7500 Series Router?
Jul 14th, 2008
I'm having trouble getting my Internet and Email to work while on VPN Client? Email and Internet work before I connect to VPN Client?Does anyone have a suggestion?
dinesh.das Mon, 07/14/2008 - 23:17
If I am correct, you are connecting to VPN from your PC, and after getting connected you are not able to access your local resource...
Then you should ALLOW LOCAL LAN ACCESS on your VPN client software...
IF this is not the case please make it clear
Cher42164 Tue, 07/15/2008 - 03:25
You are correct, and I thank you very much! I checked my VPN connection under "Modify" and I saw that the ALLOW LOCAL LAN box was not checked; I will try again tonight! I do hope that that's all it was.....Thanks again!
Cheryl
dinesh.das Wed, 07/16/2008 - 00:18
Please let me know if things are working properly,
and Please rate post if it helps!
Cher42164 Wed, 07/16/2008 - 14:51
I just tried it and it didn't work. I'm wondering if I have to do a "Port forward"? I have Verizon DSL and it is wireless on my Laptop; I can VPN fine, but nothing works while I am VPN'd in? I can't figure it out? I do appreciate any suggestions you may have.
Sincerely,
Cheryl
dinesh.das Wed, 07/16/2008 - 23:54
send VPN server configuration, so we can trouble shoot more.
Cher42164 Thu, 07/17/2008 - 03:03
How do I do that? How do I send you the VPN Configuration?
Cheryl
dinesh.das Thu, 07/17/2008 - 03:58
do mean to say you dont have access to the VPN device which you are connecting or you dont know how to attach doc on this session.
Cher42164 Thu, 07/17/2008 - 04:08
I am saying that I would need instructions on how to get you the information you are asking for. I have access to my VPN Client; I just don't know how to get you what you are asking for?
Cheryl
