Outbound calling issue with Caller ID
Jul 14th, 2008
Our setup ccm6.1 > h323 gateway.
Today we are getting caller name inside Faciliy IE. In order to get incoming caller name, we applied the below commands.
#h323
#h225 display-ie ccm-compatible
#int s0/2/0:23
#isdn supp-service name calling
We are now getting incoming caller-name, but out outbound calls are not working. I've tracked this down, and the display name (for internal use that is configured on the line) is showing up in Q931 debug. We have no ISDN outbound display-ie input on both our serial interface and on the ccm h323 gateway page.
When I take the name of the internal display section on the line, I can make outbound calls, but as soon as I input it again, outbound calls are rejected.
What can I do? We need incoming caller name and also need internal calls to show display info. Again, I have display-ie removing on both D channel on h323 gateway and in CCM gateway page.
Thanks in advance,
Overall Rating: 5 (2 ratings)
kelvin.blair Mon, 07/14/2008 - 07:31
  • Silver, 250 points or more
Do you by chance have Send Calling Name in Facility IE checked?
If so, uncheck? This may be the problem.
Ayodeji Okanlawon Fri, 07/18/2008 - 06:55
  • Cisco Designated VIP,
    2017 IP Telephony
Lee,
Thanks for sharing! 5 points for you on this!
