FWSM context in CSM 3.2
Jul 14th, 2008
only short question:
we have 6513 and FWSM 3.2 module with 5 virtual context. Which is the easiest way to add this in CSManager 3.2. I found on this forum that is the best way is to add every context manually trough specific IP address of every context. But, while adding Admin context, should I check Security Context box? As I presume, we should "see" every context as different and independent firewall?
Thank in advance
hadbou Fri, 07/18/2008 - 06:08
  • Bronze, 100 points or more
Use the Add Security Context dialog box and the Edit Security Context dialog box to define and maintain contexts for the currently selected FWSM. Note that at least one security context must be designated as the admin context.
