07-14-2008 07:15 AM - edited 03-03-2019 10:42 PM
My Cisco Router 837 have two virtual ethernet interfaces, ethernet 0 and ethernet 2, and more four physical fastethernets. When I configure the two interfaces, one as 192.168.2.1 and other as 192.168.4.2, my server ERP loses connectivity with IP 192.168.2.1 (ERP application have 192.168.1.120 IP address). Could you tell me what is happening? I think that Cisco 837 segments two ports at each network ( 192.168.2.1 and 192.168.4.2). What am I supposed to do to have the communication between the two networks and my erp doesn't lose the communication as well?
Thanks.
Best Regards.
07-14-2008 08:54 AM
Hi, the 837 should not have two virtual ethernet interfaces. Please send "show diag" and "show run" to identify what you have.
07-14-2008 10:13 AM
07-14-2008 10:38 AM
That would be use of the "DMZ" features, see:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xr/dmz_port.html
When used, ethernet2 is physically connected to fasternet4.
Just make sure that router and servers connected have consistent network/mask, and you should be fine.
Please rate post if it helps!
07-14-2008 11:28 AM
Thanks. How make routing between ethernet interface 1 and 2?
Best regards,
07-14-2008 11:30 AM
Just assign IP address, nothing else is required.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
07-14-2008 12:02 PM
I will make the test.
Thanks.
Best regards,
