07-14-2008 07:50 AM - edited 03-18-2019 09:17 PM
IS there any way I can bulk import existing subscribers into a distribution list, I have 100 users to add Unity 4.2
07-14-2008 08:09 AM
have you tried this tool?
http://www.ciscounitytools.com/App_pdl_builder_30.htm
javalenc
if this helps, please rate
07-14-2008 08:11 AM
Hi Paul,
The Public Distribution List Builder (PDLB) is designed to let administrators easily add large numbers of Unity subscribers to existing or new public distribution lists. The PDLB also allows for the creation of a new distribution lists in addition to selecting an existing list to add members to. You can select subscribers to add based on a number of criteria including importing from a CSV file or using custom SQL queries.
From the great Unity Tools
http://www.ciscounitytools.com/App_pdl_builder_40.htm
Hope this helps!
Rob
EDIT: There is my crappy typing skills again Jaime :)
07-14-2008 08:31 AM
Excellent Thank You
And you are correct Unity Tools is second to none
