Translate Calling ANI from a pool of numbers, randomly
Jul 14th, 2008
When making a call out via a VoIP dial-peer, we want to change all calling ANI number, to take from a range (or a pool) of numbers, sequentially or randomly.
How to do it?
I saw the voice translation profile can only does Calling ANI translation to a single number, not possible to "take" from a pool or range of numbers.
I only want to done the Calling ANI translation at a particular VoIP termination carrier. Hence, the commands should be applied under that dial-peer. Am I logical correct?
Thanks...
paolo bevilacqua Mon, 07/14/2008 - 09:10
  • Hall of Fame,
    Founding Member
How big and what is the pattern of the pool you want to use ?
littleindia Mon, 07/14/2008 - 09:33
The pool or range of number is from xxxx-xxxx-x001 to xxxx-xxxx-x500.
Sometimes, the range/pools will be smaller.
Hence, any calls send out via that VoIP carrier, the Gateways will translate/replace the Calling ANI.
paolo bevilacqua Mon, 07/14/2008 - 10:29
  • Hall of Fame,
    Founding Member
For larger pools, it's doable but requires a lot of configuration. Basically you would build specialized DPs based on called number, to each one to set a particular calling number.
For example, in case of a 500 numbers pool:
dial-peer voice 1000 voip
destination-pattern [01]00$
clid network-number 5551000
dial-peer voice 1001 voip
destination-pattern [01]01$
clid network-number 5551001
dial-peer voice 1100 voip
destination-pattern [23]00$
clid network-number 5551100
destination-pattern [45]00$
clid network-number 5551200
dial-peer voice 11499 voip
destination-pattern [89]99$
clid network-number 5551499
Other configuration can be made depending on the exact size of the pool.
However, I think at a certain point, it would be better to manipulate the calling number via a TCL script.
Please rate post if it helps!
littleindia Mon, 07/14/2008 - 18:23
Sorry, the post does not help.
The dial-peer is checking every destination starting prefix & assign a Calling ANI, which is not suitable for operation.
paolo bevilacqua Tue, 07/15/2008 - 02:28
  • Hall of Fame,
    Founding Member
The example I gave you programatically assign calling number based on the last three digits of called number, not the starting prefix.
This way, statistically you will be using all the numbers in pool.
If that is not ok with you, as I mentioned before, the other alternative is to use a custom TCL script for the purpose. Only that would allow you to choose the calling number in a random manner. No IOS configuration would allow you to do that.
littleindia Tue, 07/15/2008 - 07:44
I got your point. I had to use a Soft-switch to do this. Many thanks.
