Solution for VoIP and PBX
Answered Question
Jul 14th, 2008
Hi there,
I need a help from you, to have a solution with VoIP and PBXs.
So, I want to connect a VoIP machine to a PBX in order to send all the international calls towards this VoIP server.
The call scenario should be... analog phone --> PBX --> digit analysis (international) --> VoIP gateway --> other country call via IP.
Which equipment and what solution is better for this?
With best regards and thank you.
Correct Answer by Paolo Bevilacqua about 8 years 6 months ago
Hi, you need to know that, else you could end proposing a router with a number of ports that is too big or too small, that wouldn't be good I guess.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 07/14/2008 - 09:50
Which type and q.ty of pots lines the PBX have?
This is necessary to know in order to size the gateway.
Urban_Nights Tue, 07/15/2008 - 01:03
thank you for your reply.
this is a Meridian Nortel PBX.
I really do not know how much pots lines do I have...but I know that we do not have a big traffic.
Regards.
Correct Answer
Paolo Bevilacqua Tue, 07/15/2008 - 02:31
Urban_Nights Wed, 07/16/2008 - 03:16
Thank you for your answer.
I've to see the equipement fisrt, because I am in a remote side.
I'll let you know if I need something else.
Thank you and regards.
