voice broadcast traffic
Jul 14th, 2008
Is it possible for the computer behind the phone to not receive the phone broadcast.
Alex Pfeil Tue, 07/15/2008 - 02:54
I have a computer on one vlan and a phone on another vlan and I do not want the computer to see any traffic from the phone vlan.
Paolo Bevilacqua Tue, 07/15/2008 - 03:53
Hi, normally no voice vlan traffic should be visible on the access vlan, that is the one that is on the back on the phone.
Alex Pfeil Tue, 07/15/2008 - 03:57
if i plug in a network scanner (with the computers address which is on a different vlan) behind the phone I can see traffic from the phone as well as to the computer.
Are you saying that should not happen?
I was wondering if I can stop this from happening.
Paolo Bevilacqua Tue, 07/15/2008 - 05:28
disable "span to pc port".
I put the first url from a search results, you might be using a different phone model or CM version, but the concept is the same.
