PIX 525 6.3(5) and BugId CSCsb34758
Jul 14th, 2008
Like I said in the title, we have a PIX 525 running version 6.3(5) and we have the problem described in Bugid CSCsb34758:
connection to DMZ fails after PIX authentication session
We had version 6.3(4) before the upgrade and didn't have this problem... We have many users using authentication with the PIX so we need to correct this situation ASAP!
On the software bug toolkit page, the bug is reported to be fixed for version 6.3(5.108) for product ASA 5500 series. Is there a version of that patched release for PIX 525? I don't know if it's patched on version 7 but we can't upgrade to that version anyway so I really need this for 6.3(5).
Or can I downgrade to a version that not have the patch without other security problems?
Thanks!
acomiskey Mon, 07/14/2008 - 10:32
  • Green, 3000 points or more
ASA does not run version 6 code.
6.3(5.108) is a pix os.
jvilleneuve Mon, 07/14/2008 - 10:52
I don't know about ASA running version 6, but that's what it is saying in the software bug toolkit:
Status
Fixed
Severity
3 - moderate
Last Modified
Any Time
Product
Cisco ASA 5500 Series Adaptive Security Appliances
Technology
Authentication Protocols
1st Found-In
6.3(4.120)
Fixed-In
6.3(5.108)
If that's PIX OS 6.3(5.108), where can I download that version? I got the latest one from cisco and it's the same md5sum that the one I have (6.3(5))...
