vlan based QOS For 3560 and 3750
Jul 14th, 2008
Can anyone tell me of a way of policing traffic based on the vlan interface. I have a network that is comprised of multiple VM's all connected to various vlans that i would like to control the bandwidth on. I setup vlan based qos and found that you still have to applied matched traffic to a physical interface. Is there any known way of implementing traffic policing on a vlan traffic only?
Any idea's would be appreciated
Collin Clark Mon, 07/14/2008 - 11:29
VLAN based QoS is not supported on the 3560/3750. AFAIK it's only supported (stackable) on the 3550.
Hope that helps.
Patrick.Beaven Tue, 07/15/2008 - 10:54
Yes Ive looked at the link you referenced and it still requires phyiscal interfaces bound to the vlan in order to perform the policing.
This wont work for my scenario.
