6509 - X6148A: FRU-power failed
Jul 14th, 2008
Chassis: 6509
IOS: 12.2(18)SXF8
The new X6148A-GE-TX card reports:
%C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (FRU-power failed)
The same model card works fine in this slot.
The only difference on the new card is a special-shaped power socket that allows the card to be inserted into slot 5 or 6 only.
Is there a workaround?
Thank you.
Giuseppe Larosa Mon, 07/14/2008 - 12:30
  • Hall of Fame,
    Founding Member
Hello Lev,
it looks like there is a specific daughter card for Power over Ethernet
see the following link
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/release/notes/OL_4164.html
the part number is WS-F6K-GE48-AF
it requires 0.18 [email protected] V
Hope to help
Giuseppe
lioncool Mon, 07/14/2008 - 12:45
Thanks for the reply.
The PoE is not an issue as I don't have WS-F6K-GE48-AF daughter card on the X6148A-GE-TX.
