static NAT rule overlap
I have few different connections coming in to different real IPs and\or protocols, all with same inside destination (same windows machine).
I've set a security policy rule for each of them to permit inbound traffic on the outside interface.
when I try to create the static route pointing the traffic off the ASA via the inside interface to the actual server I'm rejected since teh destination (the internal IP) overlap from one static to another
how do I solve this problem?
husycisco Fri, 07/18/2008 - 09:27
  • Gold, 750 points or more
Hello Ofir,
I couldnt understand why you need a route, please paste the acls, statics and routes you entered so we can understand your issue in depth.
take this example:
access-list Inbound_Traffic extended permit tcp any host 63.x.y.100 eq smtp
access-list Inbound_Traffic extended permit tcp any host 63.x.y.101 range 2710 2715
access-list Inbound_Traffic extended permit tcp any host 63.x.y.102 range 2710 2715
access-list Inbound_Traffic extended permit tcp any host 63.x.y.103 eq https
access-list Inbound_Traffic extended permit tcp any host 63.x.y.101 eq https
access-list Inbound_Traffic extended permit tcp any host 63.x.y.104 eq www
63.x.y.101 & 63.x.y.102 are different real world IP that point to the same internal IP (192.168.1.1)
when I try to config the NAT inside - pointing 63.63.x.y.101 to 192.168.1.1 and then do the same with 63.x.y.102, I get an error
acomiskey Fri, 07/18/2008 - 10:56
  • Green, 3000 points or more
You cannot do that.
You need to do something like this...
static (inside,outside) tcp 63.x.y.101 https 192.168.1.1 https netmask 255.255.255.255
static (inside,outside) tcp 63.x.y.102 2710 192.168.1.1 2710 netmask 255.255.255.255
etc.
a.alekseev Fri, 07/18/2008 - 12:12
create an alias for 192.168.1.1 and use it for duplicated entry
gilarcejr_1127 Thu, 10/08/2015 - 05:26
I'm having the same problem. How exactly do you use an alias for the duplicate? Can you guide us please on you configs for that? Thanks
