Running multiple UC applications on one server
Jul 14th, 2008
We currenly have two 7825 (I think H2's) and two newer HP servers in our test lab and are looking to run Presence, Unity, and possibly Personal Communicator on a single server. We already have dedicated servers for CUCM.
1. Can two (or all 3) of Presence, Unity, and CUPC be run on one server?
If "yes" to #1, then
2. What are the server requirements to do this (and can the 7825's accomplish this)?
3. Are there any special rules or version requirements to run multiple apps on one server vs. on dedicated servers?
Thanks!
Greg McBeth
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 07/14/2008 - 14:33
  • Cisco Employee,
  • Hall of Fame,
    2011
unfortunately you require dedicated servers for all the applications you're going to use
few applications can be co-resident like CUCM + CRS. most of them (now with linux appliances even more) require each a dedicated server
javalenc
if this helps, please rate
