CCME FXO Trunk Groups and Outbound ephone-dn
Answered Question
Jul 14th, 2008
I currently have the following scenario, I have two FXO trunk groups on a four port FXO card.
trunk group FXO1
trunk group FXO2
voice-port 0/1/0
trunk-group FXO1
connection plar 75377
caller-id enable type 2
voice-port 0/1/1
trunk-group FXO1
voice-port 0/1/2
trunk-group FXO2
connection plar 75378
voice-port 0/1/3
trunk-group FXO2
I have two phones, one phone should use FXO1 and the other phone should use FXO2 for outbound calls.
My outbound Dial-Peers are arranged in the following manner.
dial-peer voice 7 pots
trunkgroup FXO
corlist outgoing css-loc
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 72 pots
trunkgroup FXO2
forward-digits 7
dial-peer voice 11 pots
trunkgroup FXO
corlist outgoing css-ld
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 112 pots
trunkgroup FXO2
forward-digits 11
dial-peer voice 110 pots
trunkgroup FXO
corlist outgoing css-intl
destination-pattern 9011T
prefix 011
dial-peer voice 1102 pots
trunkgroup FXO2
prefix 011
How do I get Ephone 1 to use FXO1 when making outbound calls, and Ephone 2 to use FXO2 when making outbound calls?
ephone 1
no multicast-moh
device-security-mode none
mac-address xxxx.xxxx.xxxx
type 7941
button 1:1
ephone 2
no multicast-moh
type 7941
button 1:2
Correct Answer by Paolo Bevilacqua about 8 years 6 months ago
H, you use trunk under DN and specialized DPs for that:
dial-peer voice xxx pots
trunkgroup FXO
destination-pattern 81[2-9]......
trunkgroup FXO2
destination-pattern 82[2-9]......
ephone-dn 1 dual-line
trunk 81
ephone-dn 2 dual-line
trunk 82
Note: since for all calls from DN 1 and 2 will prefix 81 and 82, you need to use that as an the second button and label EXTERNAL.
Note 2: since likey you're not restircitng local calling, don't use corlist on the related DP.
Note 3: There is also a way to do without "trunk". using corlist instead. But, check if the above is satisfying to you first.
Overall Rating: 5 (5 ratings)
Correct Answer
Paolo Bevilacqua Mon, 07/14/2008 - 13:59
trunkgroup FXO
trunkgroup FXO2
trunk 81
trunk 82
dennis.ferree Tue, 07/15/2008 - 04:57
Thank you very much, this worked well in the lab, we are depolying to a multi agent site now.
Paolo Bevilacqua Tue, 07/15/2008 - 05:05
Making customers happy, especially with FXOs, can take some time, fortunately CME has a full bag of tricks to use.
Thanks for the appreciation and good luck!
Ayodeji oladipo... Tue, 07/15/2008 - 05:03
Paolo,
Since the guy was too happy and excited about his problem been resolved he forgot to rate the post, so I helped him. +5 point for you!
davidesmith68 Tue, 05/19/2015 - 09:47
I have four lines, each are directly to the FXO port but I need to use call forwarding on the FXO port to forward to voicemail.
David
