NAT Issue between Two Networks
Jul 14th, 2008
I have a 3meg multilink connection going directly to the internet to a service providers network, then a Frame T1 that is coming back into my private network (this private network does have access to internet via different service provider). We want all internet traffic to NAT out to the multilink connection. However, we have servers that are on the private network that need to be accessed through the FR T1 on the private network. These servers will be accessed from the outside world, come through the private network and come accross the Frame T1 on the router. The below config is the closest we have got it to work. But the servers cannot be accessed via the Internet from outside the private network. Nor will any NAT translations occur out the multilink. I think this is a crappy design, but its what we are currently stuck working with. We denied the individual servers in the NAT config with an extended ACL Thoughts? Clear as mud ain't it :-)
interface Multilink1
ip address 12.89.x.x 255.255.255.252
ip nat outside
ip virtual-reassembly
ip route-cache flow
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface FastEthernet0/0
ip address 12.x.x.x 255.255.255.240 secondary
ip address 150.x.x.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $ETH-LAN$
ip address 10.0.0.1 255.0.0.0
ip access-group 103 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex full
speed 100
no cdp enable
no mop enabled
interface Serial0/0/0:0
ip address 172.16.203.246 255.255.255.252
ip nat outside
encapsulation frame-relay IETF
ip route-cache flow
interface Serial0/1/0:1
description Serial for 3mb connect
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/1:1
no ip address
encapsulation ppp
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.203.245
ip route 66.x.0.0 255.255.0.0 172.16.203.245
ip route 150.x.0.0 255.255.0.0 172.16.203.245
ip route 165.x.0.0 255.255.0.0 172.16.203.245
ip route 170.x.0.0 255.255.0.0 172.16.203.245
ip nat pool ATT 12.52.x.x 12.52.x.x netmask 255.255.255.240
ip nat inside source list NAT_ACL pool add_pool overload
ip access-list extended NAT_ACL
deny ip host 150.x.x.x any
deny ip 150.208.x.0 0.0.0.255 150.x.0.0 0.0.255.255
deny ip 150.208.x.0 0.0.0.255 170.x.0.0 0.0.255.255
deny ip 150.208.x.0 0.0.0.255 66.x.0.0 0.0.255.255
permit ip 150.208.x.x 0.0.0.255 any
permit ip 10.0.0.0 0.255.255.255 any
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 07/14/2008 - 14:17
  • Hall of Fame,
    Founding Member
It is not a crappy design.
Configure:
ip nat inside source static udp I.I.I.I 80 P.P.P.P 80
I and P are respectively the internal and public addresses for the server. Ideally, P should not be in any pool, but even if it is, nothing bad should happen.
Unrelated to that you should configure routing to eliminate the ugly static routes, and in a future, easly obtain backup for the T1. That is done via VPN/GRE tunnels these days.
Please rate post if it helps!
kenneth.rogers Mon, 07/14/2008 - 14:45
paolo.....thank you for the reply.....In this case the public IP will not have an internal address for it. They (the 150.x.x.x range) will not be NAT and will need to be accessed from the outside world, thru our internal network annd accross the frame to this router in which the server resides
I hope I am making sense in explaining this...
The static routes are indeed ugly, but due to some organization policies between us and the customer, a dynamic protocol can't be used in this case.
paolo bevilacqua Mon, 07/14/2008 - 15:04
  • Hall of Fame,
    Founding Member
Hi, you explained the issue very well.
The config command I gave you, does what you're asking for. You pick a public address and assign to an internal one, only for tcp port 80 in the example above. This has nothing to do with the NAT you guys are using to browse the Internet.
Now here's the gotcha that I forgot to mention before. Since the other site also has an independent internet access, you cannot let the reply packets to accesses from outside, to go thru that connection, because that would break the TCP.
So you need a special config called "PBR". that is policy based routing, on THEIR router, that is the one the other side of the frame relay. it goes like:
interface fastethernet x/y <-- the LAN IF facing server
ip policy route-map servers
access-list 111 permit tcp I.I.I.I 255.255.255.255 eq www any
route-map servers permit 10
match ip address 111
set ip next-hop 172.16.203.246
See also:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
Sorry, there is no easier way than that. In other words, it's magic to tell that packets going to the internet in response to an access, should transit "YOUR" connection and not "THEIR".
If you can't quite grab the concept at first, don;t worry, there's people with 5 years experience that doesn't :)
Let us know and remember to rate useful posts!
paolo bevilacqua Mon, 07/14/2008 - 15:18
  • Hall of Fame,
    Founding Member
Got a second thought. Actually thre's is an alternative in case they really really do not want to use the PBC commands give above.
That would be making a superspecial NAT so the server sees all requests as coming from one of your LAN addresses, but it's much more complicated either conceptually and practically.
So I hope you will be happy with my first suggestion above.
sdoremus33 Mon, 07/14/2008 - 17:59
  • Bronze, 100 points or more
Paolo,
So with PBR the basic principle is to redirect the traffic sourced from 10.0.0./8 that say originally was set to flow through Interface ser0/0 because of route metric decisions say for simplicity RIP has one hop over serial0/0 and two hops over ser0/1.
But you have a route map specified for PBR
like this
route-map net-10 permit 10
set interface serial0/1
traffic will now flow out serial0/1 interface
sdoremus33 Mon, 07/14/2008 - 18:01
access list 111 permit ip 10.0.0.0 255.0.0.0
sdoremus33 Mon, 07/14/2008 - 18:24
Never mind I get it now. Thanks
kenneth.rogers Mon, 07/14/2008 - 18:26
Excellent information.....it will be awhile before we can test this, but looking over some documents PBR should accomplish what we are trying to do. I will advise the discussion when we see what happens
paolo bevilacqua Tue, 07/15/2008 - 04:05
  • Hall of Fame,
    Founding Member
If you will go testing that, remember that depending from were they also access the server I.I.I.I, ACL 111 may need further tuning.
Again, the idea is that only traffic going to the internet as replies to access, will take the special path.
Thanks for the appreciation and good luck!
