BGP announce network
Jul 14th, 2008
Hi all,
Refer to below config. can router announce network 148.50.0.0/16? As I know, In order to make
BGP to announce network, interface subnet mask should be exactly match with
subnet mask under router bgp. That is below router can't announce network 148.50.0.0/16.
Howerver, if interface fastethernet 0/1 change to ip address 148.50.1.253 255.255.0.0. then router can announce it.
Is it right ?
interface FastEthernet0/1
ip address 148.50.1.253 255.255.255.0
duplex auto
speed auto
router eigrp zzzz
redistribute bgp xxxx metric 1024 100 200 200 1500
network 140.50.0.0
network 148.50.0.0
network 172.16.0.0
no auto-summary
no eigrp log-neighbor-changes
router bgp xxxx
no synchronization
bgp log-neighbor-changes
network 10.100.0.0 mask 255.255.0.0
network 10.255.2.48 mask 255.255.255.252
network 140.50.0.0
network 148.50.0.0
neighbor 10.255.2.49 remote-as yyyy
neighbor 10.255.2.49 soft-reconfiguration inbound
no auto-summary
Route_reflector Tue, 07/15/2008 - 01:11
Yes, Whatever prefix you advertise using network command in BGP should have an exact match in the local routing table as well, unless otherwise you have a summarise option.
