5350XM 12.4(15)T5 CVP 4.0(2) SIP BUG???
Jul 14th, 2008
Guys,
I have seen this before, basically the SIP call comes off my SendTOVRU node into my VXML Gateway, but the bootstrap VXML doesnt launch! I see this.. but
>>>>CCAPI handed cid 15 with tag 4001 to app "_ManagedAppProcess_bootstrap"
no vxml runs...
I had this happen before and I moved to 12.4(15)T4 it says anything this and above is supported.. ideas?
dial-peer voice 4001 voip
service bootstrap
voice-class codec 1
session protocol sipv2
session target ipv4:10.146.15.2
incoming called-number .
dtmf-relay rtp-nte h245-alphanumeric h245-signal
no vad
Chad
Chad Stachowicz Mon, 07/14/2008 - 22:27
I downgraded the IOS to 12.4(15)t4 to no success. I have never worked with the 5350 before. Also in all my CVP experience the ingress gateway and vxml gateway have been the same gateway. Anyone got some wise words why my bootstrap tcl wont launch?
Chad
jbyron Tue, 07/15/2008 - 03:05
It sounds like the bootstrap.tcl and/or boostrap.vxml files on the gateway may be out of date.
1. Do a 'show call appl voice bootstrap' and a 'show call appl voice new-call'. The State at the top for each should show "Registered". If not, the files are definitely old or missing.
2. If #1 looks OK, get a trace with:
debug voip ccapi inout
debug voip appl vxml
debug voip appl script
debug voip appl tcl
