WCS throws error while adding WLC
AbbasAliZoeb
Hi Guys.
I am trying to add a couple of 4402 WLC's to a WCS 5.0 .However on entering correct snmp parameters it throws the following error:"Failed to add device to WCS REASON: Object not found in device"
Richard Atkin
Level 4
Level 4
This is probably a version mis-match between WCS & WLC codes. Check the release notes for the software your running to ensure the versions are compatible.
Hi RitJonAtk
it is indeed a version mismatch, checked the release notes to confirm that. I was using WCS 4.1 with WLC 5.0 .
Thanks a lot....u saved some precious time (& blushes)
