07-14-2008 09:13 PM
We have ACE modules at our primary production site in an active/standby config - and have been working fine for some time.
eg.
context ace1
description context1
allocate-interface vlan 10
allocate-interface vlan 11
context ace2
description context2
allocate-interface vlan 20
allocate-interface vlan 21
There is a bridge group in each context and the ip range for context1 is 10.1.1.x and context2 is 10.2.2.x.
Rservers and VIPs in context1 are therefore in the 10.1.1.x range; in context2 they are in the 10.2.2.x range.
For a DR site, we want to use a CSS11506 to act as the load balancer in case of a disaster at the production site.
Is it possible for the CSS11506 to be configured to act the same as the ACE in case of a DR scenario? ie. Can a CSS be configured to so the same job as the ACE, maintaining the IP addresses assigned to the rservers/vips/vlans?
We need to have the IP addressing at DR to be the same the production site (vlans can be created at DR as required and are independent of the production site) - however the DR site is only 'active' when the production site is destroyed (or in testing obviously).
What would a sample config on the CSS11506 look like given the above ACE configuration?
(It's my first attempt at configuring a CSS!)
Cheers guys
Cameron
07-17-2008 09:55 AM
hi,
It is possible to have a css to do the same functionality. The context principle does not exist but you have the similar interface/vip redundancy see:
Bridging can also be done see:
Keep in mind that the policies are replaced by owner & content rules, serverfarms do not exist, real servers are called services and predictors are callled loadbalancing systems:
