SPAN on CAT 3550 shows only one way traffic
Jul 14th, 2008
interface FastEthernet0/6
switchport access vlan 30
switchport mode access
duplex full
speed 100
interface FastEthernet0/12
switchport access vlan 20
monitor session 1 source interface fa0/6
monitor session 1 destination interface fa0/12
We only see one way traffice with Ethereal connected to fa0/12
I have done this many times before and never had any problem. But I am not sure what model switch I have done this before on. May be not a 3550.
Overall Rating: 5 (1 ratings)
astanislaus Mon, 07/14/2008 - 21:42
We also modified fa0/12 config as follows and still same problem:
switchport access vlan 30 (i.e. same VLAN as fa0/6, although I thought it shouldn't matter)
dhananjoy chowdhury Mon, 07/14/2008 - 22:24
  • Silver, 250 points or more
What do you see in the output of this command ?
show monitor session 1
astanislaus Mon, 07/14/2008 - 22:48
Unfortunately when I got to be told about the problem the customer had done - no monitor session 1 by then.
But customer says - When he had the monitor session 1 commands he had the following output:
sh mon sess 1
Session 1
Type : Local Session
Source Ports : Fa0/6
Destination Ports : Fa0/12
Encapsulation : Native
I asked him if he had seen anything like Ingress or Egress disabled and he says he does seem to recall seeing that.
We will try again to see what the output of show monitor session 1 command is after tunrining on monitoring.
astanislaus Tue, 07/15/2008 - 17:33
I tried to simulate this problem in our lab and I configured as follows and show monitor shows as follows. Why does it show ingress disabled.
arvproctors01#show run | begin monitor
monitor session 1 source interface Fa0/6
monitor session 1 destination interface Fa0/12
end
arvproctors01#sho mon
Session 1
Source Ports :
Both : Fa0/6
Ingress : Disabled
arvproctors01#
garytayl Tue, 07/15/2008 - 18:13
Ingress is disabled by default however, do not get confused with t he traffic being monitored. It means that port fa 0/12 will not work as a regular port therefore won't receive packets, it is only monitoring. If you want to monitor traffic and use that port to receive regular traffic then you should used:
monitor session 1 destination interface fastethernet0/12 ingress vlan X
Gary
