How to bound DUAL NICs in CCM5.1 or UnityConnection 2.x
Answered Question
Jul 14th, 2008
I wanted to bound dual nic in CCM5.1 or UnityConnection 2.1 which linux-based OS,
I only can find the reference for windows-based OS such CCM4.x and Unity, failed to find out any reference for Linux-based.
Anyone who can give me some advice with some reference URL enclosed.
THanks
Correct Answer by Ayodeji Okanlawon about 8 years 8 months ago
The command to enable failover is..
set network failover enable.
All you need is to configure eth0 with an IP address. when you enable failover, the IP address of eth0 will be applied to eth1.
After you enable failover, a new interface will be formed called bond 0. This interface then becomes the virtual interface, so when one of the [hysical interface goes down, the virtual interface will stay up but will reference the only active/up interface
See attached a screen shot a ccm enabled with failover...look ath eth0 IP and eth1
Pls rate useful posts!
Overall Rating: 5 (2 ratings)
Chad Stachowicz Mon, 07/14/2008 - 21:55
  • Silver, 250 points or more
'set network failover' from ssh!
HTH, please rate useful posts
Chad
zhangjianping Mon, 07/14/2008 - 22:17
Thanks.
I wanna which NFT mode relatived with this CLI, active/active mode or active/passive mode?
Any reference URL?
zhangjianping Mon, 07/14/2008 - 22:57
Pls ,is any other CLI needed when failover configed?
is only eth0 needed to configed with IP?
how about eth1, a individual ip address needed or the some ip address or nothing needed?
Correct Answer
Ayodeji Okanlawon Tue, 07/15/2008 - 01:55
  • Cisco Designated VIP,
    2017 IP Telephony
