BGP advertise route
Jul 14th, 2008
Hi all,
Refering to below config. can router advertise 148.50.0.0/16 to outside, Since as i know, router can only advertise route
when the interface subnet mask is exactly match with subnet mask under router bgp xxx. But now the two subent mask are not
match (148.50.1.253/24, 148.50.0.0/16). So can router advertise 148.50.0.0/16 to outside
interface FastEthernet0/1
ip address 148.50.1.253 255.255.255.0
duplex auto
speed auto
router eigrp zzzz
redistribute bgp xxxx metric 1024 100 200 200 1500
network 140.50.0.0
network 148.50.0.0
network 172.16.0.0
no auto-summary
no eigrp log-neighbor-changes
router bgp xxxx
no synchronization
bgp log-neighbor-changes
network 10.100.0.0 mask 255.255.0.0
network 10.255.2.48 mask 255.255.255.252
network 140.50.0.0
network 148.50.0.0
neighbor 10.255.2.49 remote-as yyyy
neighbor 10.255.2.49 soft-reconfiguration inbound
no auto-summary
Giuseppe Larosa Mon, 07/14/2008 - 23:17
  • Hall of Fame,
    Founding Member
yes if one of the following actions is done
a) you enable auto-summary under router bgp
b) you create an aggregate for the net under router bgp but take care to have at least a component subnet in the BGP table
Hope to help
Giuseppe
