Can't change 2-wire to 4-wire on VWIC2 MFT?
Jul 14th, 2008
Hi-
I've been trying to find ways to change "2-wire" to "4-wire" on the VWIC2-2MFT-T1/E1 on my 2801. Any ideas?
Voice card specific Info Follows:
Operation Type is 2-wire
E&M Type is 1
Signal Type is immediate
Dial Out Type is dtmf
I tried going into the Voice port menu, but not in there.
RWCPBX(config)#voice-port 0/3/0:1
RWCPBX(config-voiceport)#?
Voice-port configuration commands:
auto-cut-through E & M auto cut-through without answer signal
bearer-cap Specify the bear capability
busyout Configure busyout trigger event & procedure
comfort-noise Use fill-silence option
compand-type The companding type for this voice port
condition Condition Signaling bit patterns
connection Specify Trunking Parameters
cptone Configure voice call progress tone locale
default Set a command to its defaults
define Define Signaling bits
description Description of what this port is connected to
dial-type Configure type of dialer for voice
disc_pi_off close voice path when disconnect with PI received
echo-cancel Echo-cancellation option
exit Exit from voice-port configuration mode
fake-answer-disable Disable E&M fake answer for trunks hung in EM_PARK state
idle-detection Idle code detection for digital voice
ignore Ignore RCV Signaling bits
input Configure input gain for voice
music-threshold Threshold for Music on Hold
no Negate a command or set its defaults
non-linear Use non-linear processing during echo cancellation
outgoing-cas Set delay on outgoing CAS connection
output Configure output attenuation for voice
playout-delay Configure voice playout delay buffer
shutdown Take voice-port offline
snmp Modify SNMP voice port parameters
station-id Configure station ID
threshold Threshold [noise] for voice port
timeouts Configure voice timeout parameters
timing Configure voice timing parameters
translate Translation rule
translation-profile Translation profile
trunk-group Configure interface to be in a trunk group
voice-class Set voiceport voice class control parameters
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Tue, 07/15/2008 - 02:25
when E&M signaling is configured on digital interface like the VWIC is, 2 or 4 wires operation is not applicable because there are no wires at all, and reported only for compatibility with the analog E&M card.
Consequently, you cannot configure that and it will not make any difference to effect of the connection.
Please rate post if it helps!
