MetroEthnernet and G.shdsl
Jul 14th, 2008
Hello;
I've got two location with connected 20 mbit site-to-site metroeth.Also there is a backup line g.shdsl 2 mbit.
Could i end the both connection on the same device ?
Also when the metro line go down,can g.shdsl become online automatically?
Thanks.
paolo bevilacqua Tue, 07/15/2008 - 02:18
  • Hall of Fame,
    Founding Member
Hi, yes you can terminate both connections on the same router.
The backup will be activated automatically only if the proper configuration is made on all the related devices, generally speaking any routing protocol will do that fine.
