interface up down status are not getting logged via console or telnet
Jul 14th, 2008
Hai we use cisco 4506 as access switches.I want to get all logging messages including interface up down status with the mac-address ..But i am not getting the logs for the interface up down status on 4506 switches..
any specific configuration is required for that...
this is my current config for one of my access switch
no logging console
logging trap notifications
logging 10.203.193.112
here logging is disabled via console .but i have configured
logging monitor
which should display the logs via telnet sessions.it's not happening..Pls suggest me a solution.
2 ly i need to to whether mac-notification feature is available in cisco-IOS features..
Regards....
Gokulakrishnan.
Overall Rating: 5 (1 ratings)
blrnetwork Mon, 07/14/2008 - 23:30
I configured "logging synchronous " on line vty 0 15 & line con 0 also and seen the logs it doesn't show any logs about interface up down status....
whether we need to give " logging synchronous level all " instead "logging synchronous "
Regards....
Gokulakrishnan.
n.nandrekar Mon, 07/14/2008 - 23:10
  • Silver, 250 points or more
hi!
You can try " terminal monitor" in order to get the logging on the telnet session. also try terminal monitor after "logging console"
Is it that you are getting all other logs but just link up/down missing???
In that case, try :
-P(config)#logging event link-status default
Niranjan
(pls rate helpful posts)
blrnetwork Mon, 07/14/2008 - 23:20
Hai i tried the above option
I given " terminal monitor " from privilege mode
i didn't get any logs
i tried to configure " logging event link-status default " but i am not able to configure that from global config mode..There is no option for that...
Regards....
Gokulakrishnan.
blrnetwork Mon, 07/14/2008 - 23:59
Regards....
Gokulakrishnan.
jamesl0112 Tue, 07/15/2008 - 00:09
  • Bronze, 100 points or more
If you have configured logging monitor - what level did you specify? E.g. wanrnings, notifications, etc.
Also, since it looks like you are logging to a syslog server - are the up/down interface logs turning up there?
blrnetwork Tue, 07/15/2008 - 00:19
I think when the log buffer is full at the switch then all the old logs will get accumulated at the Syslog server,..
but i didn't specify any level in logging monitor" i have just configured " logging monitor "
Is it not possible to monitor all events under the telnet sessions.
also i was monitoring the console logs by disabling the " logging monitor " & " term monitor " and enabling the console monitoring as " logging console " ..
By the above command it should log all the events thru console ....
it 's not happening.....
Only log which i get isattached herewith
bghsgsw601#sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 3 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 645 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level notifications, 652 message lines logged
Logging to 10.203.193.112, 652 message lines logged, xml disabled,
filtering disabled
Log Buffer (4096 bytes):
19w0d: IP ARP: rcvd req src 10.203.238.50 0060.fb51.c4b7, dst 10.203.238.33 Vlan444
*Jul 8 04:42:34.062 UTC: %SYS-5-CONFIG_I: Configured from console by bgh07668 on vty1 (10.203.237.175)
*Jul 8 04:51:35.406 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 8 04:56:57.414 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 8 05:00:49.418 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 8 06:47:41.313 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 9 22:21:57.307 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 9 23:33:45.859 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 9 23:34:46.995 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 9 23:46:18.607 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 9 23:52:49.651 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 10 01:56:45.535 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty1 (10.203.237.167)
*Jul 10 02:08:20.219 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty1 (10.203.237.167)
*Jul 10 23:30:21.453 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 10 23:44:43.529 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 13 21:50:46.548 UTC: %SYS-5-CONFIG_I: Configured from console by bghit on vty0 (10.203.237.167)
*Jul 14 05:18:16.930 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 14 05:20:35.846 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 14 22:04:39.266 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty1 (10.203.238.35)
*Jul 14 23:20:10.497 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 14 23:43:08.117 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 14 23:51:42.813 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 14 23:54:30.249 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.237.171)
*Jul 15 00:45:21.657 UTC: %SYS-5-CONFIG_I: Configured from console by bgh17581 on vty0 (10.203.238.35)
bghsgsw601#
Regards.....
Gouklakrishnan.
