MWI not working.
Jul 15th, 2008
Hello all,
I am trying to activate MWI to be on and notify the user but it doesnt seem to be working.This installation is for voice messaging.I have specified the number for MWI on both the unity and the UCM.
I need assistance with this.
Thanks in advance
Overall Rating: 4 (3 ratings)
tim.giles Tue, 07/15/2008 - 01:30
Check the integrations in Unity to make sure the ports are set up correctly. i.e. go into Start > Programs > Unity > Manage Integrations, click on the cluster and check the dialout MWI checkbox is selected.
Can you switch on/off the MWI via the numbers?
Have you selected the same on/off extension in "manage integrations" as you have in callmanager?
Please rate if useful......
sherifato Tue, 07/15/2008 - 01:59
Thanks alot Kingtim1st,
I have actually selected the same on/off extension for the Unity as it is the same for UCM.
Please can you explain what you mean switch on and off the MWI via numbers?
I will do what you said in the 1st paragraph.
Thanks alot.
tim.giles Tue, 07/15/2008 - 02:03
Basically, the numbers you've configured in CallManager act as a trigger to turn MWI on/off on the phones. If you dial the on switch on one of you phones it should turn on the light? You can then turn it off via the "off" dir number....
sherifato Tue, 07/15/2008 - 03:48
Thanks Kingtim1st,
The turning off and on off the MWI worked but how where do I have to set the MWI to automatically turn on when there is a voice message left on phones.
Thanks in advance.
tim.giles Tue, 07/15/2008 - 05:02
Ok, I've attached everything to make it easier. Make sure the intergration is configured properly either via the START menu (unity > manage integrations etc.) or from Unity Admin.
Check the box "use MWI for message notification" in the default template and make sure all the ports are configured.
You can add multiple MWI extensions by adding more internal numbers into the "extension" list. The "X" specifies the number of the subscriber and nothing else.
PLEASE rate post....
sherifato Tue, 07/15/2008 - 06:45
Really apperciate your help. Please can you explain "X" specifies the number of the subscriber and nothing else.
Thanks alot
tim.giles Tue, 07/15/2008 - 06:57
Come on, this has got to be worth a 5.0...ha ha! ;0)
For more info, go to this link, it explains everything a lot better than I can....the first one for MWI, the second explains the whole installation process thoroughly...
