Warning message
upgrade from ACS 4.1.1 to 4.1.4 or 4.2
Jul 15th, 2008
hi
i want to upgrade the acs(windows) from 4.1.1 to 4.1.4 or 4.2
there is 1 document i know ... it says
ACS 4.1.1.23 or ACS 4.1.1.24
to ACS 4.1.3 or ACS 4.1.
can upgrade from ACS 4.1.1.23, 4.1.1.24, to ACS 4.1.3 or 4.1.4 on Windows.
but when i download the 4.1.3.12 redme file it says :
Prerequisites
This is a patch for release ACS 4.1.3. ACS 4.1.3 must be installed before
installing this patch.
Other prerequisites are same as for ACS 4.1.3
so shall i agnot this notice or what ??
and if i have a cco login and i want to download a fresh 4.2 can any one give a linke to download this from cisco coz i didn't found it.
regards
Jagdeep Gambhir Tue, 07/15/2008 - 05:46
  • Red, 2250 points or more
ACS full software's are not listed on CCO and you need to contact TAC to get one.
On site all you will get are patches. Once you have a software you can upgrade using upgrade path you have.
~JG
Do rate helpful posts
