IPSec VPN
Jul 15th, 2008
Hi All
Hope some one can help. I have 2 x 2801's both fitted with a WIC-2AM and running the security IOS. I have configured the VPN using the SDM utility.
Problem - no encrypted traffic shown on the monitor but when I run the “Test tunnel” it reports it as OK.
If I run a ping between the two routers it is OK but appears not to be encrypted.
Attached the config from one of the routers, the other end is a mirror
gnich
roeeshimrit Mon, 09/09/2013 - 07:45
I see that you use a trustpoint ,
Did you verfiy you receive the Certificate successfully from the CA server ?
Kasiraman S Mon, 09/09/2013 - 08:14
Are you testing this out in lab or a production setup?
What is the source and the detination IP address you used to test to see if the traffic are encrypted?
Can you post the configuration of the other end as well.
Are they in two different location and is it communicating with the Public IP on the other end. Becasue I see the RTR 1 has a private IP and is it behind any DSL modem?
