Reg:1841 routing issue
Jul 15th, 2008
Dear sir,
We have cisco 1841 router and we terminated 512 kbps v.35 leased line is working fine .and router output is connected to switch and we have 1MB broadband and that RJ-45 also terminated on switch and we r planing to this broadband ip also planing to route through router.Is this kind of setup will work or not.If its works plz any tips .
Thanks&Regards
srini
paolo bevilacqua Tue, 07/15/2008 - 03:29
  • Hall of Fame,
    Founding Member
Yes it will work. Anyway you need to be familiar with IOS to do some advanced configuration like for backup, load balancing, etc.
