07-15-2008 03:27 AM - edited 03-06-2019 12:11 AM
A layer 3 switch
1* 2* 3* 4* 5* 6* 7*
port 1 is directly connectted to laptop
port 2 is directly connected to a server
port 1 is enabled with 'no switchport' and has IP 10.1.1.1
Laptop has IP 10.1.1.2 with default GW 10.1.1.1
port 2 is enabled with 'no switchport' and has IP 14.130.13.108
server has IP 14.130.13.109
I want to ping the server (14.130.13.109) from laptop (10.1.1.1).Is is possible that a layer 3 switch can do such function by enabling routing or so ?
07-15-2008 03:50 AM
Yes this can be done,
Just make sure you enable ip routing on the switch and you set the gateway for pc to 10.1.1.1 and for server to 14.130.13.109.
LR
07-15-2008 04:43 AM
Thanks LR.
time to read basics again for me :-)
i did not put Default gateway of Server .
it is working now :)Gr8 thanks
